Thanks. I think there may simply be a terminological issue here. I may be wrong, but I would have regarded "a DSP that multiplies and integrates" as a "microprocessor"! Indeed, when I typed DSP into Google, the first hit I got (Wikipedia) said:John I linked to a datasheet in an earlier post. It has two sigma-delta ADCs for voltage and current, and then fixed-function DSP that multiplies and integrates - plus some other clever stuff like a high-pass filter that eliminates any DC offset in the current sensing. The result of that is a digital signal of some sort, e.g. a pulse per Joule or something. That's not a microprocessor.
A digital signal processor (DSP) is a specialized microprocessor (or a SIP block), with its architecture optimized for the operational needs of digital signal processing.
Good point - and, as you say, there presumably has to be a reason. That Wikipedia article went on to say that dedicated DSPs often have much better power efficiency than do general-purpose microprocessors - so I wonder if they have perhaps been persuaded by electricity suppliers to minimise the power consumption? Although, on the face of it, the amount of power involved would appear to be trivial, I suppose it could be more of a factor when multiplied by millions of meters!It surprises me that Analog Devices have gone to the trouble of producing a whole range of chips to do it in this way if it's also possible (and presumably cheaper) to do it with a "bog standard" microcontroller and its regular ADCs, but what do I know?
Kind Regards, John
