You need:
"Yamalube 4 stroke 10W-30 motor oil is a mineral based formula with a specific blend of additives necessary for use in four stroke marine engines. It provides superior lubrication and bearing protection."
Nothing to stop you experimenting and put in other oils. It might blow, or it might work. It's very much a case of no risk no gain. But, it would be fair to presume the bike maker already experimented and found the overall optimum oil for it. Deviating slightly might not be a problem. When things are not working, you can often get signs of it in sound or smell.
