I like that,
I had a Dremel that although didn't see much use took a hammering when I did use it, didn't last long though before it died
This is what I use with the Die Grinder, 6mm to 3.1mm collet adapter, 13mm long piece of rubber pipe behind the collets (just stops it falling down into the chuck). You can then use all your Demmel bits.
I bought another multi kit for home £21.
The Dremel diamond cutting disks on the Speed Click bit are amazing really, they can cut through just about anything!.
I suppose the only drawback to the Dremel is the chuck requires two spanners, but that's due to it's power really when using the bigger 6mm and 8mm collet tools.
