POP..umm is this quite likely or not! I mean its seems very common to use this install method?? I like copper but if two plumber's quoted for a job which one would get the job, the 100% copper guy or the duel material fix guy at his cheaper price?
Hello,
I have a Greenstar Heatslave 18/25 combi, whats the best distance from the boiler before it being possible to change to plastic?? Bosch-Worcester say "Do not use plastic pipework on sealed systems"!!
Are they covering their ass or is this perfectly true for this boiler in sealed system?
so what i have got from this thread is you cannot use plastic fittings within a metre because if there is a double fault, i.e., the over heat stat and the pressure relief valve both fail the plastic fittings will fail due to the heat and the pressure. LOL, so you guys would rather have the boiler blow up than a plastic fitting fail. Got to love your devotion to copper.
I have encountered PRVs that do not lift at badged pressure but will eventually give at say 4 or 4.5 bar
Most heating systems are I believe minimum 6 bar rated.
As the system pressure increases so does the boiler point of system water.
My preference would be high temperature high pressure discharge via the PRV to external instead of plastic pipe failing and covering me in boiling water that is more than 100 degree C
Kevplumb has been away for many many years
Lot of what has been posted is no longer valid.
Manufacturers recommendation takes priority.
Resurrecting an old post not a good idea. Take from it what you want, regulations, specifications and recommendations do change with time. Post was started in 2007, 17 years later plastic is a go to pipe for most. Majority of the plumbers used to plastic might not be able to use a pipe bender and copper pipe
