Why would it not?had we been talking about a (the one and only!) female Prime Minister, then that argument as to why the ambiguity went away 'on Newnight' would no longer be valid.
I think you are probably confusing things a bit, since I still think that EFLI was not right in the way he was interpreting and regarding your question.Your doubts are misplaced - EFLI is right. The idea isn't that you solve it by complicated maths - the idea is that you deduce that the question would not be posed if the answer depended on the diameter of the sphere (and thus the diameter of the hole), therefore it must be constant for all sphere diameters ( ≥ 10cm), therefore the answer remains the same as the diameter of the sphere tends to 10 and the diameter of the hole tends to 0, therefore it's the volume of a sphere 10cm in diameter because at that point the hole has diameter 0 and no material is removed.
That's surely obvious. Men very rarely change their names (hence the reasonable assumption that the question did not relate to some past name of David Cameron - thereby essentially removing tha ambiguity), but women very often do (so either of the ambiguous questions could still be intended).Why would it not?had we been talking about a (the one and only!) female Prime Minister, then that argument as to why the ambiguity went away 'on Newnight' would no longer be valid.
OK then.That's surely obvious. Men very rarely change their names (hence the reasonable assumption that the question did not relate to some past name of David Cameron - thereby essentially removing tha ambiguity), but women very often do (so either of the ambiguous questions could still be intended).
Exactly. Do you have any problem with that?OK then.
If you take the question to mean "Who was PM in 1950?" the answer would be Clement Attlee.
If you take it to mean "What was the name of the current PM in 1950?" the answer would be Margaret Roberts.
... because if one knows that it is a 'serious question' ('on Newsnight'), and knows (or is 'all-but-certain') that David Cameron has not changed his name, then one can essentially discount the interpretation of "what was the present Prime Minister's name in 1971", hence almost eliminating the ambiguity - whereas, since the PM was female at the time (and hence pretty likely to have changed her name in the previous 35 years), the same was not true in 1985.No, but I fail to see why there is any less ambiguity if one changed the dates to now and 1971....
Quite so!Shame the forum doesn't support the necessary font.If I had written 166.7π, someone may well have said that was 'inaccurate'. Similarly if I had written 166.67π, 166.66667π,or even 166.66666666666666666666666666667π - so I thought it 'safest' to put 500/3
Indeed, or some other equivalent which left no doubt as to what you were asking (like the suggestion I posted a page or two back). I'm not quite as daft as you might think, and 'predicted' that someone was going to misinterpret the question in the way that EFLI did - which is why I 'warned' you, immediately after you first posted the question, that 'an increase in clarity' would be desirable.So - lessons learned.
1) Rephrase the Q to specify that the sphere is a uniform solid with a density of 1g/cm³ and ask for the weight of the remaining object.
I suppose so (unless the forum comes to accommodate more fonts!), but that's pretty trivial compared with (1). [FWIW, I'd call it 'recurring', as in "6 recurring", not 'repeating']2) Pick a diameter which does not result in a repeating answer, e.g. 12cm.
I probably should have suggested two other things...Indeed, or some other equivalent which left no doubt as to what you were asking (like the suggestion I posted a page or two back)....So - lessons learned.
Isn't that just a special case? What about 4/7?FWIW, I'd call it 'recurring', as in "6 recurring", not 'repeating'
Maybe times have changed, but I was brought up to call it 'recurring', whether it one one digit, six digits or however many digits that were repeated, with symbolic representation such as:Isn't that just a special case? What about 4/7?FWIW, I'd call it 'recurring', as in "6 recurring", not 'repeating'
Lest some manage to misunderstand the question again, may I suggest that it should be clarified that not only did he not paddle any harder when going downstream than when going upstream, but nor did he paddle any less hard - i.e. his paddling was exactly the same when travelling in both directions.Amyway - a man is paddling a boat upstream. He passes under the first of two bridges one mile apart. As he passes under the second, his hat falls into the river, but he doesn't notice immediately, In fact, he doesn't notice for ten minutes, at which point he turns around and paddles back to retrieve his hat, but doesn't paddle any harder than he had been doing before. He catches up with his hat just as it passes under the first bridge.
How fast is the river flowing?
