Yes, so this is essentially a 'semantics' puzzle (some would call it a 'trick question') but, given that, I don't think BAS really was precise enough with his semantics - hence my original question.Mmmm well he did ask the volume of the sphere rather than the volume of the solid still remaining therefore the volume of the sphere is still the same.
He asked "...what is the volume of the original sphere remaining". If one is going to be semantically pedantic (which I guess one has to be, if the puzzle is essentially semantic!), there in NO 'sphere remaining' - there is a name (which I've forgotten!) for a sphere with a circular hole right through one axis (the first step in changing a sphere into a toroid), and it's not "sphere"! ... which makes one wonder what he actually meant (and, of course, most people will probably assume that he means 'the amount of material remaining in the solid sphere').
The "volume" of a 3D object is defined as the volume contained by its (continuous) surface - and that certainly does not remain unchanged if you drill a hole through a sphere. The "has not changed" answer is an answer to a different question - something like "what is the volume after drilling if one imagines that the entry/exit holes are not there and that the part of the ('containing') surface of the hole joining the poles does not exist". If I gave you a large washer (or even a doughnut) and asked you to determine its 'volume', would you really calculate the volume it would have had if the hole was not there?
Kind Regards, John
