Eh?
Kind Regards, John
Not in what I read..
Eh?
Kind Regards, John
Yes, I realised that's what you meant, but (sorry!) it doesn't alter the fact that I am a bit lost ...Not in what I read..
... If measurements gradually change and then 'settle down', despite your not 'touching anything', that can be due to capacitance/.capacitors associated with whatever is being measured.
What 'also' were you saying that I hadn't?Also true if there are capacitors in circuit, charging up and/or long cables, when measuring high resistance values/insulation.
Kind Regards, John
Not at all - I was merely wondering whether you had perhaps thought of (but forgotten to mention) an 'also' which I had overlooked, given that the only bit of my post which you quoted (when you wrote "also ... capacitance") was that relating to capacitance! In any event, I hadn't noticed that your comment related to measurements of high resistance, so we are 'quits' in terms of not have read carefully/fully enoughFact is I speed read and had not spotted your mention of capacitance. Is it really such a big issue if we both mention it?
I was wondering if moving the commutator could be inducing some kind of interference.
I may remove it from the housing and see if it reduces the variance.
Just to point out, I was not looking for accurate measurements per say. I was following a fault finding guide.
The guide suggested that while the values did not matter in themselves, a damaged bar would show an inconsistent result compared to the general value the others gave.
I was confused as I was seemingly getting wildly different values all the time.
I can actually see which bar is damaged, so I was more trying to see how that may manifest itself in a reading.
Unfortunately a bad connection while zeroing out the leads can very much result in under-reported readings during the real test.The saving grace is that, provided it is correctly calibrated, what none of these meters can do is produce a reading which is less than the true resistance,
That's very true, and I suppose that I was thinking of 'zeroing' as part of "correctly calibrated".Unfortunately a bad connection while zeroing out the leads can very much result in under-reported readings during the real test.The saving grace is that, provided it is correctly calibrated, what none of these meters can do is produce a reading which is less than the true resistance...
I've certainly seen a zeroing facility on a bench multimeter, not sure if any handhelds offer it.
My analogue ones do
So do mine, in a sense, but it's certainly not intended as a means for compensating for test lead resistance when measuring small resistances. Since it's just a mechanical adjustment of the pointer, I imaginee that if one tried to use it to compensate for lead resistance, that would go wrong because of the non-linearity of the scale, wouldn't it (even if one had an analogue meter that could sensibly measure very low resistances)?My analogue ones do
That would not really address the issue being discussed here, would it? No matter what equipment or methodology one uses to measure a small resistance, the accuracy of the reading will be at the mercy of the quality (resistance) of the connections between the measuring equipment and whatever is being measured.An accurate ( but inconvenient way to measure resistance is the Wheatstone bridge method.
Kind Regards, John
Not for a 4-wire measurement.That would not really address the issue being discussed here, would it? No matter what equipment or methodology one uses to measure a small resistance, the accuracy of the reading will be at the mercy of the quality (resistance) of the connections between the measuring equipment and whatever is being measured.
Kind Regards, John
