Hmm. I was right. I stated my position, and think that is clear to most. Then you answer my questions with a question.
Nice diversionary tactic.
Funny old world isn't it? We criticise an inherently intolerant religion as is perfectly demonstrated in this case
Your question:Hmm. I was right. I stated my position, and think that is clear to most. Then you answer my questions with a question.
was rhetorical and didn't require an answer.Are you too blind to see that the story that sparked this whole thread is an example of extreme bigotry? Or is it that it's just the right type of bigotry to fit your narrow view?
Which religion do you think I was referring to?
Your post makes no sense
So we assume, by elimination, you were responding to my post when you said:Funny old world isn't it? We criticise an inherently intolerant religion as is perfectly demonstrated in this case
I didn't quote your post as I wasn't replying to it. It was a general quote about the subject of this thread - nothing to do with protestants. Unless perhaps the gypsy is one.
I suspect that the rules and regs of the cemetery would simply not allow it.
In fact, I suspect that the family need special permission to backfill the grave themselves.
Thanks Hugh. I was aware.In response to RNReindeer,I suspect that the rules and regs of the cemetery would simply not allow it.
It was, (and I suspect still is permitted), common practice at West Indian funerals for the men to backfill the grave whilst the women sing and wail for the deceased.
Some cultures require that the grave is filled in while the family watch or they may wish to undertake the backfilling of the grave themselves. When families want this it is essential that the cemetery is made aware of their requirements when the burial is first arranged. This will ensure that the family's wishes are met and that their safety is protected during the backfilling process.
http://www.lancaster.gov.uk/cemeter...remations-frequently-asked-questions/[/QUOTE]
No one is allowed to trade or work in our cemeteries without the written permission of ICCS.
3.8.1 All excavation works and backfilling of graves is carried out by ICCS staff
unless backfilling by mourners is agreed with us. ICCS may allow family
backfilling to take place under their supervision if a family wishes to do this but prior approval must be given.
http://www.islington.gov.uk/publicr...-Camden-Cemetery-Regulations-2011.pdf[/QUOTE]
Create new cemeteries.How is a multi-faith cemetery sustainable, in the long run?
Unless you are going to leave significant areas unused (which wouldn't be a good idea - we're already running out of burial plots in UK - http://www.bbc.co.uk/news/uk-24283426), someone is going to end up next to someone their relatives will object to, at some point.
Slough Cemetery opened in 1932 and has been extended since that time. The Muslim section, XH, is located in the North East corner of the site:
The image below, taken in September 2008, clearly shows the different orientation of the graves on the Muslim section to meet the requirements of the local Muslim community:
http://www.slough.gov.uk/moderngov/mgConvert2PDF.aspx?ID=7818[/QUOTE]
So you quoted my post and took my example of an intolerant Protestant and turned it into an example of Islam?
I notice you haven't yet replied to the direct question
Suddenly remembered he's supposed to have me on ignore.So you quoted my post and took my example of an intolerant Protestant and turned it into an example of Islam?
In case you haven't noticed, this thread is about islam.
