dave9, most wires are made of one thing: copper. However, the colours of the insulation MATTERS because what if mr DIY comes along in a couple of years to fit a new plug or something, and finds you've put the wrong wires everywhere? What's he going to do (being an average DIYer with a severe lack of multimeters and common sense, like a lot of DIYers when it comes to electrickery)? Put blue to N, brown to L and g/y to earth, the logical way to do it, no matter what you've done before. Then he turns the lecky on, and the metal case of whatever he's plugged in becomes live, and he dies . . . . you want that on your conscience?
All electrical connections should be insulated, and protected from harm. Didn't we go thru this last time??? In your case, the best way is to use a plastic box or 2 with flex glands. Cheaper to use 1 box - less glands to buy. In fact, buy a large adaptable box, and fit a socket on the front of it, instead of the trailing socket. Then you just have a box with 2 plugs hanging off it.
I am giving you these suggestions in order that you might take them and end up spending a bit of money, since you are determined to keep this setup. Please stop trying to do electrical things on the cheap!
Go and buy a couple of metres of 3-core flex, and a bit of choc-blok too, and rewire the lot with an earth. Contactor doesn't need an earth afaik, but that trailing socket DOES (how is mr average, who may inherit this "thing", going to know that this doesn't have an earth? I doubt he will open it up and inspect)
