- Joined
- 2 Nov 2005
- Messages
- 3,395
- Reaction score
- 245
- Country
Gave the Venturi a visual.
First point is you shouldn't be in there messing about really.
How can you give the venturi a "visual"
The ONLY way to get at the venturi is to remove the fan.
It will have lots of hard crusty deposits on it which will need removing. I use a small file..
this morning, the Mrs turned the hot tap on for a few seconds and after that..... the fan stopped.
I then ran the water for longer to let the boiler kick in. Following this the fan started again.
I will say it again. That is a boiler flow switch fault.
