ChrisR said:You might have to take the venturi bits out to clean it all.
Agile said:It works backwards to other boilers so is difficult for experienced gas engineers to remember sometimes.
When it retracts it puts the fan into slow run mode.
Sometimes the spindle gets dirty and does not fully retract. The spindle may need removing, completely cleaning, drying and lubricating with silicone grease and probably a new gland.
Tony Glazier
If it had got stuck 1/4 of the way back, could this cause the slow fan not to come back on?
Would there be any benefit in turning the electric off, then applying a little silicone grease to the visible shaft when the water is on, ie the rod is out?
