Enjoy
Not with you there. I don't think I've mentioned boiler mods.I see Maintap is avoiding direct questions again.
Fixit, what boiler mod are you talking about?
I have dropped no clanger. Read the thread from the beginning. I know some dross creeped in.I've been watching this for a while and see a few of the more respected chaps are on here,but I'd like to know were hard work s going with this.Are you a sales rep or something or have you technical knowledge in the gas field or are you just having a pop at the forum or just a pop at the good people on this forum because you've dropped a few clangers in your posts which makes you seem a bit silly and hard to follow at times.
He was told by me here there was a difference between the valves, but he developed an attitude - as many of the uneducated here do.I was only querying mwgs's assertion that there's no difference between the two types.
Amazing this one thinks he can lecture me on gas controls.
Just think of 48 foot of 1" hose pipe. The water flows out in volume but not great velocity. Remove 24 foot of the 1" hose and replace with 24 foot of 1/2" hose pipe. The water will come out faster and go further. The water velocity in the 1" pipe will not change much, but the water in the 1/2" will be faster. Nothing is being sucked. Equate that to a gas pipe with a negative pressure valve.According to that, the vacuum for a negative pressure valve is not produced by the fan directly, but the fan is in positive-pressure mode and uses a venturi to produce negative pressure.
I tried with you but failed. I now give up. Even fixitflav tried.There’s no difference unless you can explain it ?
You can’t. It’s not hard really. Please try
You are not an idiot, but moving that way. Sort yourself out.It’s
There is no difference. You don’t have the knowledge to prove other wise.
