D
Deleted member 221031
57kw running of 15mm. That’s a quality install.
Navien’s Claim of being able to run off 15mm is only the same as other manufacturers who produce the gas tail in 15mm. They aren’t saying 15mm will be enough. You need minimum WP.
All modern boilers are Negative pressure. Just because the fan pulls it doesn’t mean you can get away with a smaller pipe.
