@stem I don’t want to spend any extra cash on a system that works and I just want the Nest to work in a similar way to the Randall. I’ll go with what you already suggested. I’ve asked before but that should work fine right?
Yes it will work, but as we have already ascertained you will not have any thermostatic control of your stored hot water, or be able to have the central heating on without the hot water also operating.
So, basically what you have now. But with the additional room temperature control provided by the nest.
So, the Nest stat is in according to @stem wiring diagram and I can confirm it works perfectly. I have all the features that the nest offers, I just can’t have heating on without hot water also being on at same time, which isn’t an issue.
Thanks to all and especially @stem for his advice and wiring diagrams!!
