Hi guys,
I've wired up the Nest thermostat (3rd generation) to my combi boiler, which is a Baxi 105. The heatlink is showing up a green light, so all perfectly fine there.
However, when changing the temperature on the thermostat, it says it's warming up, but the boiler is not firing up at all, even changing to a higher temperature, still not kicking in...
On the boiler, there is a tuner to change the hot water and radiator temperature, but if I turn up the radiator to full, then it will start heating up, further than what is instructed by the Nest thermostat, so it looks like the thermostat is not quite taking over the heating control of the boiler?
Is there something I need to do? There are no errors showing up on the thermostat or in the app, so not sure what to do at this point.
I've attached a photo of the boiler that is firing up when the tuner is on full.
