Why have you resurrected an old thread? They were definitely a good boiler, but not so good that their efficiency can increase with age. Your man is talking out of his proverbial.
showing 80% efficiency
I take it he plucked that off his flue gas analyser?
I serviced some boilers today. My FGA told me they were 98%. Did I equate that to operational efficiency?
No.
Now, where was that CPA1 discussion again?
A 26 year old Netaheat will be unlikely to have 80%. Maybe NETT, maybe.
I know these boilers inside out and they were NEVER 80% efficient no matter what the installation configuration. That's all I was trying to say and if you take offence at comments on what you post then why so tetchy?
What was the point of your post? If you air your views on a public forum, then be prepared to be contradicted. If you don't like contradiction then..................
Its pretty obvious that a new boiler is going to save a lot of CO² emissions and save gas as well!
possibly a car, and the manufacturer says the car will do 40mpg urban, and you find you get 45mpg out of yours, could it possibly be that the manufacturer is erring on the lower side to cover any nit-picking.
You know nothing at all about this particular boiler installation, and you may be generalising, but to cast aspersions on the quality of the work, or the standard or condition of the plumber's electronic equipment is totally uncalled for.
Or perhaps the test performed by the manufacturer is completely different than the one performed by yourself?
I often wonder how boiler manufacturers or test houses come up with efficiency numbers, some of the efficiency readings would make me believe they are testing in a Botswanan greenhouse with one radiator and the TRV turned to 1.
Seriously though, the efficiency test on an FGA is for the efficiency of the combustion of gas, not how effective the boiler is at using that perfect, or imperfect, burn to heat a water jacket.
Your boiler is putting out a healthy 80% combustion efficiency, Dan robinsons ones were putting out 98% maybe because they were condensing boilers and as such had lower flue temps giving better combustion efficiency. Obviously standing and running losses will contribute to the overall efficiency too and a lot of that obviously has to do with the design of the heat exchanger(s) and internal pipework.
In short the more heat the boiler extracts from the amount of gas input clearly means a better efficiency. Your boiler sadly has a lot of standing and running losses and so is likely to be far less than 80% overall efficiency. The exact number will be unknown to anyone, but a close guess can be taken from the SEDBUK numbers.
