Most domestic circuits now require 30mA RCD protection owing to the way the cables are installed, one thing you need to take into consideration is what happens should an RCD trip. It is no good if a single RCD feeds a whole installation - a simple fault on an appliance can plunge the whole house into darkness.
Using RCBOs is one option, using a board with more than one RCD with sockets and lights split i.e. down sockets and up lights on one RCD and up sockets and down lights on the other is another option.
You need to remember that only the neutrals from the circuit supplied from an RCD connect to the neutral bar for that RCD - if you start mixing them up then the RCD will not hold in.
