10 rads on a 30kw boiler! That is massively oversized you will probably find your boiler is short cycling and going into anti-cycle mode which is why it takes so long to respond.
The engineer didn't spec for your neighbours property as well did he
I suspect you idealise the past, as well as benefitted from the inefficient boiler heating the room it is in.
central heating has never been a form of instantaneous heat??rads are calculated to raise temp to design temp over at least two hours.
Also if the heating was off for a long time then the fabric of the building will have cooled to ambient temperature..so that had to be heated up too..
run it 24/7 and it will get there...
10 radiators on 30kw... madness.. I have 8 radiators on 5kws to give you an idea.
Dean's diagnosis is spot on..
your best bet is to invest in vaillants controls so you can lower the heat output in heating to a more sensible size...
great Dean, a man who sees the failings in our industry and does not idly blame installers...thats refreshing..
yes, over sizing boilers is very misguided..and with respect what do you know about heating technology?
most pros calculate boiler size as 1kw per radiator and 1 for the pipe work... even that over sizes a fair bit.
as said upgrading to vaillants controls will resolve the issue...where in London are you...
