How soon after you adjusted the thermostat did it trip?
Very quickly, within a few seconds I'd say...
It is hard to isolate the problem without test gear. Last house had loads of things on one RCD and could run for 2 years no problem, then trip 10 times in a week, no fault found and another 2 years trouble free.
As a result this house all RCBO which is a RCD and MCB combined, so any fault limited to one circuit.
As an electrician I have three tools to help me, or at least should have.
1) Insulation tester - this puts 250/500/1000 volt depending on selection between two points and it measures the resistance, this is the main tool, but failed to find any fault with it in my own house.
2) The RCD tester - this normally puts 15 mA, 30 mA, 150 mA on the RCD to show it will not trip too soon, will trip at 30 mA and will trip in 40 mS at 150 mA all tests done with both positive and negative half cycles so 6 tests in all.
3) Clamp on ammeter - this is used to see what back ground leakage there is during normal operation, should be less than 9 mA, I have never done this test, as don't have a meter which will go down to 9 mA.
The problem is where there is a neutral to earth fault, as this can point to the wrong item, in the main one thinks the fault is some heavy current user, where really it is some light current user and the heavy current user has caused the voltage between earth and neutral to increase and so cause the trip.
I hope the BG Homecare electrician has now found your fault, however you must ask yourself is it worth changing the set up and using all RCBO's rather than a RCD shared by many circuits? When I put two RCD's on the last house, you could not get single width RCBO's, so I had no option, loosing a freezer full of food just before I moved, made me fit all RCBO's to reduce the risk, and when my roof leaked, I lost just a few sockets which I could do without.
Only other one I’ve had (just thought of it), have you hung anything up recently, a photo or mirror perhaps? This happened to me, and the spark was blaming the boiler, and I said it can’t be the boiler, as it’s happening if she charges her phone on the hallway socket (boiler was in the kitchen). Turned out she’d hung something and punctured the cable.
That is correct, but when one sees an unusual reading even if within limits it points to a fault.999M Ohm and in others 1.6M Ohm, although he says the 1.6 is still a pass...
Looking at the pipework suggests a recent change to a Y plan, (Which needs a H/W off wire).
I have often seen the neutral wire used for this purpose and a borrowed neutral from any convenient source nearby.
Try feeding the heating from a non RCD source to see if fault persists.
Where is the programmer ?
That's a bit tricky in my case because I don't think I have any sockets that are not protected by the same RCD... I only have the single RCD protecting all circuits,
when I moved into my house, the ground floor (excluding kitchen) socket circuit had more earth leakage than the others. The utility room was damp and had an old washing machine and fridge in it, and a socket behind the sink. The sockets were full of builders dust and grit.That is correct, but when one sees an unusual reading even if within limits it points to a fault.
have you got a separate cooker supply circuit?
