By the other half of that truth, I guess you mean the 10s of thousands the vaccine has saved……you know which you ignoreQuite so, but only half the truth. To be credible, you must grant the other half of that truth.
windrush
Boris Johnson has apologised for referring to black people as 'piccaninnies
Conservative leadership hopeful Boris Johnson has defended his infamous description of black people in Africa bearing “watermelon smiles
The trouble is the data contained within is quite old for some metricsThis was published 4 days ago.
https://www.ons.gov.uk/peoplepopula...les/coronaviruscovid19latestinsights/vaccines
Go on, ignore that too. Maybe this was published too soon?
@transam Can you translate this into English?Maybe to you, allow that others might perceive better. Take down your straw man #3, and open your mind a bit.
The quote shows they're tracking variants for all cases, not just 77 cases. Sorry you weren't capable of working that out.
Invalid arguments of no value, do show your motivations.
Look here https://www.ft.com/content/d315be08-cda0-462b-85ec-811290ad488e
It explains the obvious quite clearly.
Or here "Data on omicron's severity is "encouraging" says Fauci"
I don't know if those are behind a paywall, - add Bypass Paywalls Clean to your browser.
Also bleedin obvious but I'll point it out in case some muppet thinks it's a major breakthrough: even if the pathogenicity is low, the rate of rise of cases may be such that the effect on society is still high. A sound reason to increase vaccinations to "flatten the curve", again.
To try to find causation from association is beyond my mathematical skills and definitely beyond yours. For you and me it is simple, association is not causation.No, I'm talking about the simple logic of your statement "association is not causation". This will be true in some cases but not in all, and so the full truth is:
association is not always causation
but
association is not always *not* causation.
reports of adverse reactions.
Piccaninny (or pickaninny): Child; esp. of negroes or South African or Australian natives. That's what it means, why apologise?
Watermelon smiles: how is this a racist insult? It's a very evocative and literary description of a happy African face.
Indeed, as was that which you quoted - almost a month old...The trouble is the data contained within is quite old for some metrics
Indeed, as that which you quoted is almost a month old...
But now...
"Antibodies from Pfizer vaccine may be up to 40 times less effective against Omicron, first lab tests suggest"
How would you teach a child, or someone with a childlike mind, that a particular word is offensive without referring to that word?How has thinking of all these offensive words affected you?
