"Or"securespark said:electrocution & facing the wrath of the DNO.
Teahead said:Hi Fred, hows Wilma.
My dads mate is a time served spark but is not Part P certified. He knows what he's doing and would be able to do anything i wasn't to keen or sure of doing. I had thought that you had to get a part P certified spark to do the works or can you do all the work and get it tested/certifed by Building control before getting the Lectric board to move the meter tails.
newspark_paul said:I know this is a DIY site so most of the replies will be from non-sparks, but I'm staggered that there are replies that recomnend you 'just pull the fuse' or let it fall out. Switching off the CU should mean you have no current being drawn, but if you get it wrong any current will flow through you. I don't know how much you value your life mate.
ELZ4742 said:why would you get an arc if there was no load? however, i agree its not advisable for an amature to attempt but i am surprised that you being a spark wouldnt do it.
do you have an advert in your local rag saying something like this?
"electrician, full rewires, extra garden lights etc... no fuse board changes though."
if you call the board and notify, your within your right to do it.
Spark123 said:ELZ4742 said:why would you get an arc if there was no load? however, i agree its not advisable for an amature to attempt but i am surprised that you being a spark wouldnt do it.
I wouldn't do it because I don't need to do it. I have access to all the circuits that I need access to at my place of work.
Afaik it is only if you obtain the distribution network operators permission that you can pull their fuse.
Spark123 said:I did not say wait for the DNO to pull the fuse, I said "afaik it is only if you obtain the distribution network operators permission that you can pull their fuse." If you don't gain their consent then pulling the fuse/breaking the seal can be looked upon as an offence under the ESQCR.
pcboffinuk said:If you are careful, confident (but not over confident) and can read and follow instructions from a book there is no reason why you couldn't handle changing a CU, although the sticking point will be doing the testing.
If you say BC will be inspecting it then they may well send in a spark to test things, and possibly even provide a certificate, although the problem will come if anything fails.
Because changing a CU affects all the existing circuits it means that ideally all the tests should be done on all the circuits, and if your existing cabling is poor then there may be problems there.
I'm not trying to put you off, just warn you of the pitfalls.
I don't know how much you know about electrics, but the fact you have identified it as a T-N-S shows you know more than the average DIYer. If you don't have one already, the IEE On Site Guide would be a very worthwhile purchase and should tell you almost everything you need to know and at about £17 shouldn't break the bank.
Spark123 said:It does sound like TN-S, can you borrow an earth fault loop impedance tester and check the external loop impedance?
