I got as much water out as would come out of the valve, it was hard to contain the water so some kitchen roll was needed but it didn't seem like there was very much water in the air side (maybe a couple of shots worth at most). I'll see what the pressure is like when I get home and then fire up the system and see what the pressure difference is this time.
Can the valves be changed in place or do you need to open up/take off the ev in order to change it? its a bit of a tight fit to even get to the valve so probably not likely changeable in place anyway though.
Any Bike Shop will stock schraders valves & wee tool to remove/replace them.
In my experience it's not common for the EV diaphragm to be ruptured. Mostly drain the system through the DRAIN VALVE, new schraders valve, pump up the air pressure & fill the system again......Job done!!!
