The NTC is an....Presme the NTC will be bypassed if 4 is not wired. What will the consequence of this be?
It means that the stat will not be quite so inaccurate as it would otherwise be. But its not a big concern for what you are trying to do.accelerator to limit hysteresis, so not hugely important.
Given this thread is getting on for four pages, for what is basically a simple two wire switch replacement - I would stick to what we have already suggested many timesis it feasible to add a neutral to term 4?
Instead of using terminals one and four, you need to use one and three.
You didn't say where the switchanble live would go in that case, so I assume it is capped off.
Then learn this...Thanks I am learning.
Only use suitable test equipment such as a multimeter or 2 pole voltage indicator.I tested the blue with electrician scredriver...
