@Gasguru
@ScottishGasMan
@denso13
@lightning
On the Xtramax (my old boiler) just checked it has a flow limiter of 16 l/min.
Even though it has a delta 35c of 11.4l/min ... and is 28kw > both less than the Ultimate.
Which is why we are noticing a significant reduction in shower pressure - although it is actually still reasonable.
So it seems that the flow limiter may actually be the way to compare expected shower pressures ??
I am not sure if removing the flow limiter is going to improve the situation ... how can I know that. At max hot it is doing 10l/min from the kitchen tap.
Is the question then, when I am in a shower if the temp handle is under max hot ... does that mean there is unused heating capacity that would be available if the limiter was removed or perhaps enlarged ??
If I reduce the boiler's hot water temp from 60 to 55, then the shower pressure noticeably drops ... does any of this indicate anything?
@ScottishGasMan
@denso13
@lightning
