HI All Sorry for the long Post!!
Had the central heating system renewed about a month or so ago. New Valliant Eco Tex 28K, 11 EcoRads and all piping new. The only bits left from the Old system was the Pump, Hot Water Cylinder, Water Tank and Header Tank. I use to have a micro bore system with 10mm Piping previously which had seen it selby adte!
The new system installed, installer tested the system for 1 hour and then said all was OK. As summer was warm we did not need heating BUT now we call for heating Radiators warm up slowly, Boiler keeps switching off, house eventually does get slightly warm. Installer been back 3 times once to change pump wiring as pump use to run on even after heating was switched off until digital therometer was set to lower temp which then switched off the pump. Other time they tried to remove airllock by use mains pressure to remove airlock. Valliant engineer has looked at the boiler and said its an airlock problem as heat is not dissapated by the pump and rads too quickly and why boilers cuts out! NOw INstaller has said they will not come back to rectify the problem unless we go for a sealed system!! Anyone know where I stand and what the problem is? Many thanks in advance.
