boiler manufacturers stipulate a flow rate at a certain temp rise, say the worcester say a 14lt per min @ a 35 degree rise that means if your water temp coming into the property is 15 degrees the boiler will supply 14lts per min @ 50 degrees, so the higher the temp the less flow. If you do decide to install in the loft take precautions against frozen condensate discharge.
