It is a piece of brass sweated to a piece of copper.
Even if it is a SP switch?On meters with an inbuilt switch, access is available to both the Line and Neutral outgoing terminals.
Hmmm. In terms of the language I speak, I'm not sure how that would qualify as "DP" ("DP isolator")....when we used to install isolators they, despite being DP only switched the live.
As I said, that's what I would have expected to see, but it's now been confirmed that, just like it looks, it's just a lump of brass! I have to say I'm surprised - but if I suppsoe that if they are getting a voltage drop method to work satisfactorily, then it's probably a fair bit cheaper than it would be with a transformer, even when one takes calibration process into account.I would suggest that the small device on the bus-bar in the meter is a small CT.
How bizarre.The isolator was DP but only the Live was connected to it, the Neutral was in a Henley blockHmmm. In terms of the language I speak, I'm not sure how that would qualify as "DP" ("DP isolator")
Wontdothatagain: It would be instructive to know what the 2 ICs say on them, if you still have that meter open.
Quite. Even if (as seems to be the case) DNOs and the regs they work to do not require DP isolation, I certainly can't think of any harm that can result from DP isolation - so, as you say, to do what has been described is simply a waste of money!!It shows that certain DNO fitters do not know what they are doing! _ Why spend more money on a henley block, when the Isolator could have been properly wired up in the first place!
Wontdothatagain: Thanks for that. It makes sense - a dual op-amp, processor and serial eeprom. I guess the first version had EEPROM built into the processor.
...can you expand on it...
