What's temporary about it? Sealing water leaks always works if all sources are sealed.That's just a temporary bodge, if it even worked initially. Which it probably won't.
You must be captain obvious in disguise. If people did it right, do you think we would still be here?Do it right .
Nothing is cheaper and faster to "gunk" it up. 5 minutes and £6.50. Shopping 20 minutes.Says the man who gunk's tiles up with sealant when it's quicker , cheaper and easier to swap a Redland stonewold over on the bottom course duh !
stonewold £2.00- 3 minutes.. I better you went indoors and told your mrs how clever you were MwhaaaaNothing is cheaper and faster to "gunk" it up. 5 minutes and £6.50. Shopping 20 minutes.
OK, you win. Come do my roof repair for £4. You make 100% profit. My tiles are marley and red - looks grey only to the non-expert jobbers. So, be sure you use the right stuff, none of that cheap rubbish, and offer 10 years no leak guarantee.stonewold £2.00- 3 minutes.. I better you went indoors and told your mrs how clever you were Mwhaaaa
Wrong. The only bodger who's been up there is the so called pro roofer used by the house builder. He deliberately cut a hole in the end tile to leak into the soffit. After 30 years, it's finally fixed, by me.No thanks , the tiles are covered on crud , obviously some bodger been up there before , the flashings are wrong too..
You continue to be wrong. Both channels were cut just enough to feed into the soffit. This is how we can tell it's a "pro" job. As often the case, pro's fail. Because the soffit survived and soon to be looking like brand new.Hole.. looks like a damaged channel , probably caused by some diy nut far ting around with his gutter
