Yes, that’s the cream one to assist the Megaflo. The original on the heating side was red (which makes sense) got replaced with the gray one (less so).
* Is there an Integrated Flow Check valve in the Wilo Pico pump that might allow a pressure difference
- No evidence the PICO pump has such a device; plus hard to see how it would have this effect
* Might the pump benefit from a run of the de-aerator function?
- Pressed the button & waited 10 mins while it ran, will advise IDC
* Could the old Califei(?) air-vent at the top right of IMG_1490 be holding some air?
- We were told to keep the black plastic bleed screw locked down to avoid air being sucked into the system
PS: And thanks for the continued input. Very much appreciated by both of of us.
No, no check valve, I have one of those pumps myself.
I've also installed a few of these pumps in relation's and I didn't use this air venting function in any of them, no harm in using it, it just varies the pump speed up and down for this 10 minute period.
What you might try, even though not the recommended mode, is PP (proportional pressure), note the pump power in watts, W, in whatever CC mode you are now running on, CC2?, then turn the setting knob anticlockwise into the houses, stop turning it occasionally, it will then flash the selected PP head and then display the power in watts, keep adjusting it until the power is exactly the same as it was in CC mode, see does it make any difference.
Just open the Caleffi AAV blanking cap now and then to check for any air.
