I ain't really got a clue to be fair,
I thought it was a good professional job.
No bypass neededit is a Vaillant boiler. Perhaps posters with knowledge of this brand will tell you if bypass required
Far from it.
What is the make and model of boiler
May also need a bypass if there is none and boiler needs this
Why are there two cables going to right hand spur unit and why the single insulated wires between the two spurs.
Ask the fitter to produce his unvented ticket as this appliance needs approved installer to fit.
Good to see balanced cold feed installed unless my eyes are playing tricks
Is the boiler benchmark completed?
Did you get the flue gas test printout.
Ask for gas rate and inlet gas pressure ( in majority of cases will not be 20mb)
Check with manufacturers if the boiler has been registered.
Now have seen it is a Vaillant boiler. Perhaps posters with knowledge of this brand will tell you if bypass required
Shame as the the st699 was a simple but good programmer. But a new install should be upgraded to comply.as others have said, wiring is a shambles, and getting modern appliances and keeping that programmer is just stupid
I would have been scared to turn it off, they die for funShame as the the st699 was a simple but good programmer. But a new install should be upgraded to comply.
True but when they work they are as simple as can be.I would have been scared to turn it off, they die for fun
So is Cant, not that he worksrue but when they work they are as simple as can be
Have not received benchmark, certificates or any paper work yet, I guess he's waiting for final payment before any documents given to me.
It is not permitted to withhold commissioning documentation in lieu of payment. Benchmark and associated FGA readings are legal documents and must be completed and left with the customer/appliance upon commissioning.
Why did you post this OP? Did you have doubts or did you do it yourself?
If it is fully completed, is safe and you are happy, then that is all that really matters to you. A lot on here don't like seeing shoddy work where the customer is paying top dollar, or shoddy work in general, and rightly so. I was never the tidiest of workers, but I did complete the work, and it was safe.I posted this as it was asked.
I had no doubts whatsoever and was pleased with thd job, plus was supporting a local tradesmen.
No i didn't do it myself, I couldn't even put a screw in the wall
