Hi
Just moved into a new house with a detached (by 3 metres) garage. The electrics in the garage are fed via 2 core underground steel stranded cable but had no separate fuse box, no earth rod etc. I ripped it out as I fitted a new light as the old one didn;t work and that stopped working after the second time I turned it on. So:
1. The feed seems to come from a ring feeding the kitchen off a 30amp fuse - I assume this should be on a separate fuse? Is this dangerous otherwise?
2. There is no earthing rod in the garage and there is no earth in the armoured. Is it possible they used the steel as the earth? Is this a bad thing to do?
I want to re-use this cable later to supply a consumer unit with 16amp MCB for a couple of sockets and 6amp MCB for a couple of strip lights. What is your advice, rip it out and start again? If so, what should I be running, 3 core armoured with earth from the house or 2 core and an earth rod in the garage.
Thanks for any help you can give.
Graham
Graham
