NO! We are talking about connecting an item to a potential for which it is not intended. Whether you think that is a safe potentail or not doesn't matter, it is still misuse.
I say "supposedly" because I'm firmly of the belief that in practice it would be almost impossible to isolate something like a metal bathtub from earth effectively enough in the average house so as not to pose a shock risk anyway. Even the IEE Regs. recognized this well over half a century ago by adding to the part about metalwork being either effectively segregated or bonded a clause indicating the bathtubs must be bonded. I find it perplexing that we're now in the 21st century and this seems to have been forgotten.Won't you have to qualify supposedly?
I have to agree with John that this is getting rather silly. We're not talking about hooking up the casing to 1000V and then saying "Look, the insulation has broken down."NO! We are talking about connecting an item to a potential for which it is not intended. Whether you think that is a safe potentail or not doesn't matter, it is still misuse.
Well, great minds think alike!I have to agree with John that this is getting rather silly.
Just to throw this out there, I was called to look at a fault at a house where the main switch RCD was tripping. {.....}
A better example of the dangers of incompetent installers and failure to test.Just to throw this out there, I was called to look at a fault at a house where the main switch RCD was tripping. {.....}
An excellent example of how earthing the metalwork anyway was better
Goodness! If the casing of a Class II appliance might not "be able to withstand" a pd of 230V between exposed metalwork and contents, I wonder what might happen if one applied a pd of 500V relative to earth to that metalwork (hence ~500V relative to the neutral conductor within the enclosure)Speaking of testing, does the holy grail of BS7671 actually demand insulation testing from exposed metalwork of class II fittings to true earth?
But there should be no paths to earth - it's a Class II item.Through any other path to earth which is provided by connection or contact with the units concerned.
You may not.Take a group of typical class II things like a TV, VCR, DVD player, audio amplifier, satellite receiver etc. all interconnected. Then grab a Belling-Lee coax plug or satellite F-connector which has earth potential on the shell and go to connect it to the appropriate unit.
Not allowed to be.And once that connector is in place, the whole lot is then earthed through that external connection anyway
There's a difference between a short test and continuous stressing of the insulation.I guess we shouldn't even think about Meggering from L & N joined together to the casing then?
I am finding it increasingly difficult to work out whether you are being serious or not! Are you really seriously suggesting that there is some doubt that the casing of a Class II item could "withstand" a pd of 230V across it continuously (even that assuming that a live conductor is in contact with the inside of the case, which is unlikely)??There's a difference between a short test and continuous stressing of the insulation.
