Yes.
There's a clue in my earlier post.
And if you add a class I wall light to a room, surely you've done exactly the same?Because you have introduced a hazard which was not there before.You install a class II light fixture, for example, but bolt an earth onto the metalwork anyway. How is the result any different than if you'd just chosen to use a class I fixture instead? Either way you end up with a light fixture on the wall or ceiling which has earthed metalwork.
For a start, the cumulative leakage due to capacitance which results when numbers of such units are interconnected.What are those reasons?Going back to Winston's points about audio-visual equipment, while many consumer devices might be class II, there are very good reasons for providing an earth to the casings anyway, especially once you have five or six such units all connected up together.
Doesn't that rather make the point? How much consideration has seriously been given to the adoption of double-insulated washing machines, with or without metal casings?Please let me know when you find a plastic washing machine.
If you're referring to the fact a manufacturer has chosen to declare a product as Class II, then I really don't think that is relevant. As I understand it, that declaration means that the product satisfies the requirements for omitting the (which otherwise is effectively the default) earthing of any exposed metal, and does not in any way mean or imply that any harm would/could be done to the product by earthing any exposed metal (if that could be done without risk of damaging the product).Yes. There's a clue in my earlier post.
Not necessarily.If you're referring to the fact a manufacturer has chosen to declare a product as Class II, then I really don't think that is relevant. As I understand it, that declaration means that the product satisfies the requirements for omitting the (which otherwise is effectively the default) earthing of any exposed metal, and does not in any way mean or imply that any harm would/could be done to the product by earthing any exposed metal (if that could be done without risk of damaging the product).Yes. There's a clue in my earlier post.
Fair enough, but my experience is not in industry, this is a DIY forum and the context of the discussion has been domestic!Not necessarily. Class II equipment with exposed metal is quite common in industry, ...
As you will be aware, I sympathise with that as part of a general dislike of there being any 'unnecessarily earthed' metal around - but I would not feel inclined to issue a 'warning' that it should not be done. Do you know why the industrial equipment to which you refer comes with such a warning?... and usually accompanied by a warning that it shall not be earthed.
My experience is in industry. I can't say if such things are common in domestic appliances/accessories.Fair enough, but my experience is not in industry, this is a DIY forum and the context of the discussion has been domestic!Not necessarily. Class II equipment with exposed metal is quite common in industry, ...
Of course, you're not a manufacturer!I would not feel inclined to issue a 'warning' that it should not be done.
It is a requirement of many product standards.Do you know why the industrial equipment to which you refer comes with such a warning?
I'm not - but what I was meaning is that I cannot think of an (electrical) reason why, if I were a xxx manufacturer, I would feel the need/ inclinationOf course, you're not a manufacturer!I would not feel inclined to issue a 'warning' that it should not be done.
OK, so we're passing the buck 'up the chain', without getting an 'electrical' answer. In that case, my question becomes "Do you know why many of the product Standards have such a requirement?".It is a requirement of many product standards.Do you know why the industrial equipment to which you refer comes with such a warning?
Apart from your professional experience, you presumably live in a domestic environment, just like the rest of us. You could look around your home and see how many Class II items you have, and then determine how many of them have exposed metal parts - I doubt that it would be many, if any.My experience is in industry. I can't say if such things are common in domestic appliances/accessories.
As far as domestic products are concerned the wording is usually "This product must not be earthed".but I would not feel inclined to issue a 'warning' that it should not be done. Do you know why the industrial equipment to which you refer comes with such a warning?
Yes - but much as you and I would agree that it would, on balance, be better not to earth it, would you actually use the words "must not"? (particularly given that, as we know, there are at least some people who sincerely believe that, on balance, it is better to earth it)>Much the same as if I fitted the ubiquitous metal bath on wooden supports with plastic pipes and placed a sticker on the bath stating "This bath must not be earthed".
You've jumped somewhat away from my question, but I know that's what the wording on domestic Class II products usually says, my question (about both domestic and industrial products are concerned), is "why?"As far as domestic products are concerned the wording is usually "This product must not be earthed".... Do you know why the industrial equipment to which you refer comes with such a warning?
Are you suggesting that they are simply saying exactly the same as me - that, in general (and whether it is an electrical product or not), avoidance of any earthed metal is desirable - or are you suggesting (which I would find more difficult to understand) that they feel that it could/would in some way impair the safety of the product itself?I am sure it just means that "This product must not be earthed (because it is safer that way)" rather than - "This product must not be earthed (because you shall bring doom and pestilence to my product and the world if you do)". We have made it Class II for your safety; do not negate the benefit of the product.
Yes if I had installed it so that was the case.Yes - but much as you and I would agree that it would, on balance, be better not to earth it, would you actually use the words "must not"?
In my scenario it isn't; they would be wrong.(particularly given that, as we know, there are at least some people who sincerely believe that, on balance, it is better to earth it)
