Hi all, long time reader, first time poster.
I have a very simple gravity-fed system, open vent, no valves, and one pump for the C/H. Open vent is just a tee off near the header tank. Then there is a common pipe (for both supply and the vent) going to a T on the hot water cylinder supply.
We are no longer getting hot water. Problem was intermittent for a long time, but now it's permanent. The water is not freezing cold (but close enough) - there is SOME heating going on. The primary system feed to the cylinder is nice and hot (upper pipe) but cylinder "out" is not hot at all (the lower pipe).
My old man thinks it would be worth pressurising the system with mains pressure as there could potentially be an air-lock in the heat exchanger, but I don't see how that can be possible given that the supply from the header is exactly in this location. Also the problem used to be intermittent.
Any thoughts would be very welcome.
Cheers, Matt.
Cheers, Matt.
