No need for the anile attitude Bamber. He said the HW exit pipe from the cylinder "sounded empty" and
"XXX NO HOT WATER FROM TAPS WHATSOEVER, ONLY COLD XXX"
which is ambiguous. Only cold taps...? He did not say he had cold water coming from the hot taps. Gasmanuk was also unsure.
I do not "know it all", I have no special knowledge.
I'm sure we all know all about how to solve this one but the problem persists after several answers, from you and others.
It will be at the valve, check the Hot water pipe as far away as you can, even better if you can get under the floorboard.
Is not a very helpful answer. The diverter valve might be stuck but draining a system doesn't usually do that, and removing the head from the valve to have a looksee is surely more sensible than taking up floorboards?
BarnsleyJohn put the HW on to heat , with the cylinder stat turned up, and the CH off. Does the lever on the end of the valve move without resistance(stuck uopen)? Or are you pushing against a spring when you move it?
COuld be other things wrong, like pump is stuck, or needs bleeding(remove central knob/screw, twist knob or insert screwdriver and twist)
