If you are at a last resort/dead end with this noise then you can now buy artificial grass which you could be laid on your roof, it may be worth a try.
Roof Noise – Good News, problem fixedIn my first posting I said we had a 20mm warm roof, this was a mistake and should have been 100 mm.
The original roof was felt and was perfectly quiet.
To reduce the noise from the roof when it heats or cools, we wondered whether a sedum roof (a green living plant layer) on top of the GRP roof might be a solution.
Does anyone have any thoughts on this?
The noise from GRP roofs seems to be a recent phenomenon, but these roofs have been available for some years. Could the noise be due to the added insulation layer under the roof?
Any thoughts?
Are cold GRP roofs noisy?
Except, of course, you wouldn't have had an air gap unless you had a cold deck.The major difference has been to reduce the amount of air space, and so the roof is 4 inches lower than previously. This has removed the need for the long screws. If I can get details of the fix I will forward them on. The problem doesn’t seem to have had anything to do with dampness, cold deck or warm decks
I can only tell you that my problem has been fixed, and I have a beautiful, and quiet, grp covered roof. It is 4 inches lower than the original grp roof (which replaced a felt roof).Thanks for the feedback but pulling it apart and starting again seems a bit too drastic for now though in more desperate moments I have considered it! This morning I came up with the idea of putting some decking on the top which would reduce the impact of the suns rays and therefore hopefully reduce the temperature fluctuations. It did then occur to me that the decking might make some noise but it would n't be in the cavity and therefore probably not so noticeable. I wonder if anyone has tried this approach? My builder is at something of a loss with this as he has n't come across it before. I think the issue is because it is a bit of a sun room and on hot days the sun really beams onto the roof... As I said my previous approach of putting insulation + felt on top did eliminate the noise but interfered with the way the water was running off and caused dampness so I have some confidence in my new idea which will allow the water to drain as planned as there will be space under the decking. What do you reckon? A plus is that I can do it myself.
Best of luck. I was getting the noise at Midnight as the roof cooled as well as in the day in sunshine and rain. We have a grp roof at the height of the original felt roof. The grp roof was originally installed 4 inches higher.Thanks for that information. You seem to be saying you added another layer onto the existing roof which which is what I did a while back but dismantled in the winter storms because it was interfering with the rain running off and causing dampness. Yes, like you I found that enabled quietude to return but I dare not try that again because of the general layout and the way the flat roof adjoins the main sloping one. I am still thinking it through but I think if I keep the direct sunlight off the fibreglass that will help and is not a major upheaval. As an added plus it will also reduce the sound of rain on the roof... It is only a real problem when we have this glorious weather. Another sunny day here in Wales!
