Not normal Meter Tails, Concentric?
Thanks, they seem to have sleeved the concentric cable at the meter, is that normal? I guess it is split concentric cable then? Equ to 25mm tails?
Those cables look like 16mm split concentrics & 16mm DI tail.
You could bore thro from meter box and run new 25mm supply. either concentric or tails, ready for new metering(THTC meter will go).
Looks like TNC-S with split con going away to the two boards.
That's a series 6 house service cut out. That would usually indicate a TN-S supply. The series 7 (ie no earth block at the top right) would normally be used for TNC-S. Of course the series 6 can be reconfigured internally for both TN-S and TNC-S but the lack of the PME sticker does suggest TN-S.
I have ordered 3m 25mm tails, and an isolator so when they come to change the mater, I can get this connected for easy isolation for CU upgrade later.
Cheers,
