The voltage and current relationships at the load end of the system mirror those at the generating end though. The voltages on each live pole are 180 degrees out of phase with each other as referenced to the neutral, but the direction and phase relationship of the currents through each side of the load are no different than they would be without the neutral being connected, so they aren't actually out of phase with each other.
Hmmm. There is obviously no such thing as absolute voltage, so when we talk of 'voltage' (and hence phase) we are referring to a potential difference relative to some reference point. ....
Start by visualizing a simple 480V transformer winding with just a 2-wire connection to an installation, at which two 240V 60W lamps are connected in series across the supply. Obviously the currents through each lamp must be identical and must be in phase.
Now add the neutral conductor between the transformer winding's center tap and the mid point between the two lamps. You know that if the loads are perfectly balanced on each side of the supply there will be no neutral current. The instantaneous direction, phase, and magnitude of the currents through each lamp will not change in any way.
I agree that adding the neutral changes nothing, but whether the currents (and voltages) are in phase (with or without an N connected) again depends upon what one uses as the reference.
Imagine that, as is very commonly the case, the loads have N and L markings on their input terminals. Particularly given that there is usually an expectation that N will be close to earth potential, it then becomes conventional to measure voltages relative to N. If you connect the two loads in series across the 480 supply with the L terminal of one connected to the N terminal of the other, then I agree that conventionally measured currents will be in phase in the two loads. However, if, as would be the case in the arrangement we're actually talking about, one connected the two N terminals together, then, relative to that reference point, the currents in the two loads would be 180 degrees out of phase.
The fact that, with most systems, N is close to earth potential makes this particularly relevant, since will will then have an interest (safety-wise, for example) to talk in terms of voltages relative to earth - and that is what really matters to a consumer getting a 2-wire 240v feed from the system we're discussing. As I've said before, consider two adjacent properties with 2-wire feeds, their L's coming from different sides of the transformer. Now connect a 'widow-maker' between sockets in their two houses and it will become apparent (at least to me!) that the two supplies are out-of phase! If they were truly in-phase, in a 'perfect' situation plugging in the widow-maker would have no effect.
It might be easier to think about this in terms of a DC supply - with N connected to the joining point of two batteries in series. It is then very clear that, realtive to the 'common'('N') conductor, one L is providing a negative supply and the other a positive supply. Again, connect the L of a 'postive' property with the L of a 'negative' one and you'll get a bang!
Well, BS7671 has now decreed that to be so, but that's the whole point of the argument - Up until now BS7671 has correctly recognized it as a single-phase system, as did the Wiring Regs. for decades before they became BS7671.
Indeed. I've agreed several times that the apparent change could result in some serious confusions and misunderstandings - although, as has been said (and as the BGB does) one always includes the phase angle in the description, any ambiguity actually vanishes.
Also, consider the old 3-wire d.c. distribution systems which also had a neutral. Being d.c., you couldn't call those multi-phase, could you? The single-phase 3-wire system under debate here is just the a.c. version of the same basic arrangement.
See above. One obviously wouldn't normally use the word 'phase', but would talk of polarity. However, if you're talking of the direct analogy of the a.c. system we're discussing then, yes, as above, I would call it a 'two polarity' (c.f. 2-phase) system - since, relative the their 'common' (which would normally be more-or-less at earth potential), one L would be providing a positive supply and the other a negative supply.
Please note that I'm going to be a bit out of circulation for the next day or two.
Kind Regards, John.
