old telephone wire colours
The telephone needs to be restrapped as follows:
Telephone is wired as follows. The standard diagrams are (N806, N810, N841 & N846).
The bell or ringing device should be 4000 ohms resistance. This can be rectified by either fitting the correct ringer or by inserting a 3.3K resistor in series with the ringer. The telephone should already be fitted with a Rectifier No. 205. If one is not fitted then it is recommended that one is fitted.
Remove strap T6 - T7
Remove strap T4 - T5
Insert strap T5 - T6
Red wire of line cord to T8
Blue wire of line cord to T6
Insert straps T16 - T17 - T18 - T19
White wire of line cord to T18
Green wire of line cord to T15
Insert a 3.3K resistor between T4 - T5
Insert a Rectifier No. 205 (if needed) between T1 and T2
http://www.britishtelephones.com/pstconv1.htm
For non UK cord details see
http://www.britishtelephones.com/pstconv2.htm
