Not strictly true. The usual cable construction is twisted pairs, with each wire of a pair sharing the same colours. WHITE/blue and BLUE/white is a pair. WHITE/orange and ORANGE/white is another etc, etc.The colour is not important as long as you use the same wire at both ends...
Splitting the transmission path A&B wires (terminals 2 & 5) over two pairs can degrade both the speech and ADSL signals.
Point taken but in a short internal cable run it won`t make any difference,if the pair coming from the exchange to the end user is on a split pair it will effect the capacitance balance and when tested will coming back as a unbalanced pair.A few metres of internal will make no difference.
So it's fine to screw up inside because BT might have screwed up outside?
