One for Drivel
It's illegal to fit a noncondensing boiler![/b]
It isn't as long as the exception is met. Not sure about se and u-ducts coming into it. Worth looking.
I know there were boilers which USED to be fittable to U ducts! They aren't any more!
I think they still are.,.,.it needs some more research.
As the flat on the top floor, how about feeding a plastic flue and air pipe up the se-duct. Is it accessible from the roof? Then the se-duct is by-passed. It is being used a duct for the flue pipes. Or a two pipe flue with exhaust into the se-duct and fresh air taken from elsewhere.
Checked the Gledhill Electramate, thanks, but it's 4 times the price, a bit low on CH output, not available quickly, and won't fit the cupboard because of pipes.
Did any of the makers give any reason why their boilers will not work in se-ducts? There is no apparent reason for them not too, especially the rail burner models.
http://www.idhee.org.uk/ExceptionsGuide.pdf
A condensing boiler cannot be fitted in a se-duct. It is an exception so the non-condensing boiler can be fitted to the se-duct.
However like Tony, I'm sure I read in one of the the trade rags that a condensing boiler model can be fitted.
Yes I know, I have the document! However it's quite old so I checked a couple of mfrs.
I suggest you get it from the horses mouth, in case it changes :
http://www.planningportal.gov.uk/uploads/br/BR_PDF_PTL_CONDBOILER.pdf
It isn't an exception, you just have to use a different flue route. You don't get points for it like you do for a back boiler.
In this flat as I said, you could fit a condenser (and come under the 1000 points) but it would be a pain.
Poking pipes up the exhaust duct would be foolhardy - you're interfering with other people's flues and could easily land yourself and them in cack.
If you cant penetrate the walls or ceiling for whatever reason - and that is for whatever reason and that may be aesthetic, or a landlord policy - then you can fit a non-condensing boiler to a U-duct. That is a valid exception.
A landlord would not allow you to penetrate the ceilings walls on a high rise block - it is invariably a no, no for structural as well as aesthetic reasons.
I would have fitted a decent rail burner non-condensing combi.
And that would have been another illegal installation.
Exceptions are not given for U ducts, or aesthetics.
Ferroli modenas widely installed in Glasgow L.A housing u ducts about 5 years ago
If the installer can't fit the boiler because of condition outside of his control, exception comes in. I would have fitted a non-condensing boiler in the U duct - legal. You have given a tenant a poor deal with high electric fuel bills.
That IS drivel! You can't just make up whatever rule suits you.
There is a points system, whether you/I like it or not.
I have already told you a condensing boiler could have been fitted, but it would have been in an inconvenient position.
The fact the old boiler was into a U duct does not affect the issue.
***Incorrect information removed. MOD.
I know all about the points.
***Clearly not. MOD
