I do apologise for this question as the answer may seem obvious to the professionals on the forum.
Well here I go I have a gas powered back boiler wwith a danfoss 15/50 pump this system is running 8 radiators, the problem I am having is identifying in which order they heat up.
The one in the bedroom directly above where the back boiler is heats up first so I assume that is the first in line but after that it is hard to find the correct order they heat as they seem to vary the order in which they heat up.
The reason for my question is to enable me to balance the system.
I would appreciate any help
Thanks Miko
Thanks Miko
