We had a new Ideal condensing boiler fitted last September. Previous CH was semi gravity, open vented system, oil boiler. Our plumber is very competent and conscientious. He is now tearing his hair out.
We started to get air in the rads. Three in particular (two of which have been moved in the past) We had to keep bleeding them and topping up. He suspected a leak but then discovered the expansion tank didn't have correct pressure. Thought we'd cured the problem. Had a period of 3-4 weeks peace and quiet. Alas. we then started to get banging in the boiler. Ideal came out and said the differential reading was 33 instead of 11% - must have a blockage. System was Powerflushed yet again. Banging stopped but we are now back to the 'air' in rads problem. He has since fitted a new expansion tank. We still get squirting, running water type noises when the CH or water first switches on. When it's actually running it's fairly quiet. The noise in the hot water cylinder is worsening now and if you try to bleed the rads there's hardly any air but fizzing water. What on earth is going on. Our plumber is extremely depressed.
