A plastic box such as: https://cpc.farnell.com/europa-comp...nkmPBQKuMmVr6Wvu7AWJa38kVIEDjIKkaAtp-EALw_wcB
But chose a size that works with a socket inside.
Edit:
keep the wall wart indoors and extend the low voltage cable.
Hope you like the correction.Mains is low voltage. Did you mean extra low voltage?
That'll be the one thenI've used one of these previously for a transformer plug that had to be located outside...
https://www.electricalcounter.co.uk/products/Switches+&+Sockets/Weatherproof+Accessories/Nexus+Storm+IP66/Single+Outdoor+Weatherproof+Unswitched+Socket+IP66+(Large+Housing)/3527567921
It looks like there are several plates in there, can they be moved around to accomodate wallwarts with the bigger bit below the pins?I've used one of these previously for a transformer plug that had to be located outside...
Brilliant find and not bad at that price, a google search comes up with the same thing at up to £40Yes, they're pretty much Euro modules, so you can set the socket as top, middle or bottom, depending on the shape/direction of the wall wart.
