That type of fitting often doesn't have any facility/aperture for entering a surface cable. They tend to be designed as rear entry.
Any reason not to situate the FCU outside?
It also doesn't need to come on every time a cat/fox/badger/muntjac/whatever wanders past.I guess I’ve confused matters by calling it a “security light”, this was my original intention when I started this thread weeks ago. But since then, it’s main purpose will now be to light an new paved around round the side of the house where the wheelie bin and recycling containers will be stored. So the light doesn’t need to be situated out of reach.
No need to perpetuate bad practice, surely?Just to match the other outside lights on my house and the others on the development.
It’s a very good point your make and I’m all for reducing light pollution. But I can’t see how I’d add a switch unless it’s one of those outdoor ones. I wouldn’t really want a wall switch in the living room - it’s in the external wall of the living room that the light will be mounted.It also doesn't need to come on every time a cat/fox/badger/muntjac/whatever wanders past.
Put a non-PIR light on a switch then you can turn it on when you need it and off when you don't.
Good idea, easy to do that. The bulbs are replacement - if “led modules” means bulbs.No need to perpetuate bad practice, surely?
I would suggest simply not putting a bulb in the top section, but you've chosen a light with non-replaceable LED modules...
