I have 2 outside lantern lights connected to a 2 gang switch in the hall way.
the funny thing is they were both working fine until I tried to play with the switch on the actual light switching from PIR TO NORMAL MODE and after that I get the light flicking the untouched one works fine. I checked the connection in the 2 gang switch seems fine, disconnected the outside lantern I get power from the live cable only (RED) coming from the 2 gang switch which seems ok I changed the bulb put a 40w (max capacity 100w) looked at the circuit board I clean it with some perfum but still flicking the other one is fine.
does anyone have a clue shall I try with a 100w bulb although I did not check the connnections where the bulb is sitting???
