To heat up an open vented HW cylinder to the desired set temperature, the boilers flow temperature obviously has to be higher, but how many degrees higher?
Too low a flow and the cylinder called for temperature, would never be satisfied.
Previously, with mechanical stats, I have just ensured the cylinder stat does open and set the flow to match a satisfactory cylinder heat level.
