- Joined
- 11 Jan 2009
- Messages
- 1,095
- Reaction score
- 6
- Country
Hi
Have another problem related to this! Have cut the nozzle to required length and used jubilee clip to secure but water is still leaking from where the dishwasher discharge hose connects to the nozzle.
Is there meant to be an optimum overlap between the hose and the nozzle?
Also is it possible that I've over tightened the jubilee clip?
Never had this problem with the old joint.
Finally there is also another leak on the joint on the right where the compression joint meets the waste pipe. I'ts probably that the black washer is not seated correctly. Can someone also advise how best to connect this.
Many thanks and sorry for being so dopey.
L
L
