Pan connector misalignment makes me want to cry, please help
23 May 2010
Tyne and Wear
I have a 90deg connector, offset about 40 deg from the horizontal, but ideally need the pan connector to extend backwards from the pan outlet about another 60mm (there's a joist in the way). I'm loathe to use a flexy connector as have heard nightmares about the pan seal being inadequate and/or solid waste building up in the corrugations within the connector.
Does anyone know of a supplier/manufacturer who does rigid connectors with varying distance/length back from the pan before the turn, or failing that, a genuinely dependable flexy pan-connector?
Much appreciate any and all top tips, many thanks,
Sam
