slippyr4 said:
surely the LABC could either:-
- perform their own testing or inspection that has nothing to do with a BS 7671 test & inspect
or
- sub contract an electrician to do a PIR and keep the results for themselves
In my understanding, both of those solutions would fulfil the obligations of part P, but the DIY'er would be left with an incomplete EIC, which is not desirable for a whole bunch of reasons.
I hope i'm missing something. Thoughts and comments, anyone?
I think what you're missing is the separation of the Building Regulations and the IEE Wiring Regulations (BS 7671).
The former do not require compliance with the latter.
Compliance with the Building Regulations is required by law, compliance with BS 7671 is not.
Compliance with the Building Regulations does not imply compliance with BS 7671.
It is possible to do work which contravenes BS 7671 but does comply with the Building Regulations (good luck in convincing LABC of that, though...
Crucially, compliance with BS 7671 does not provide compliance with the Building Regulations - there is the matter of notification, and certification of compliance with the Building Regulations.
1) If you use an electrician who can self-certify compliance with the Building Regulations, he will almost certainly work to BS 7671, provide you with an EIC, and via his scheme organiser notify the work, and that is how you will then get your Building Regulations completion certificate.
2) If you use an electrician who cannot self-certify, but can work to BS 7671, and issue EICs, and who the council accept is competent, he will give you the EIC, you will show that to the council (who you will already have notified and to whom you will already have paid a fee), and they will look at the EIC and give you the Building Regulations completion certificate.
Real VFM that....
3) If you DIY, or use an electrician who they do not regard as competent, then what should happen is that out of their fee they do the I&T and then they issue the completion certificate. (Assuming the work is OK). As you point out, it is for them to decide what they should do in the way of I&T, and since the Building Regulations do not mandate working to BS 7671, there is no requirement for them to inspect & test to BS 7671, or issue a PIR or an EIC. And if they do issue one, or if they subcontract to an electrician who issues one, then I don't see that they are under any obligation to give it to you. You have paid them for the work associated with determining compliance with the Building Regulations and the issue of the completion certificate.
If you want a EIC, and they won't give it to you, then you have to go with routes 1 or 2 above.
